Hi there,
Not sure if this is the correct section (or forum) for such a question but I'm after the advice of someone who knows their stuff about car exhaust systems. I'll get some pictures up over the weekend too.
I've got a Mazda Mx5 fitted with a (badly designed) aftermarket turbo kit. The turbine outlet has a cast iron elbow which leads into a downpipe which goes down into the transmission tunnel and then curves to run parallel with the driveshaft. On the horizontal section there's a flexi joint.
I've been having lots of trouble with the nuts which hold the cast iron elbow onto the compressor outlet. They seem to work loose after hard use (trackdays). I think it might be because the downpipe length before the flexi is quite long and therefore acts as a lever on the turbo. The nuts holding the turbo to the manifold and elbow to downpipe are fine, but are in a different plane.
I've thought of bolting the downpipe to the engine block to stop this levering action. My question is; is it better to clamp the exhaust between the turbo and flexi or just after the flexi? I think before flexi but I've seen both done. I know the flexi should be on the vertical section but I don't want to get into major exhaust fabrication just yet
Also, because of clearance issues with the elbow the studs are so short that I can't use the nuts with locking "dimples" at the top as the stud thread only just reaches the top of the nut. I've found squeezing the nut slightly in a vice helps but was wondering if there is a better solution out there anyone is aware of?
Thanks,
Dean
Thanks,
Dean
