SirDick Diodenob esquire
I am needing a new battery but want to avoid spending a lot replacing the 180ah truck size battery already in place as the tractor is not used much. The best value I can find searching is a Yuasa silver 5000 size 019 from Halfords priced at 139.99 Euro which works out at £100 and is £20 less than Halfords UK are charging probably due to the recent strong pound, the idea is that I can use this also in the car. Anyone know if this is a bad idea or will the battery get knackered double quick. The spec for the starter motor states that it takes 325 amps so the Yuasa battery having a 900amp cca should be ok ? Have been using a Clarke 400 amp assisted start charger/booster but this used with a failing battery will not turn the starter motor fast enough so I am also thinking that the claims made by Clarke of 400amps may be exaggerated although it starts cars and vans easily even with a completely flat battery.
- they turned up eventually
