Hi just thought I would let you know I have managed to adapt my sip 100 amp mig to run on battery power using 3 car batteries - reason being to be able to weld where there is no mains electricity. This was done as follows:
one car battery connected to 800w 240v inverter with welder plugged into it. Welder set to lowest current range. This provides the power to the wire feed motor.
The other two car batteries are connected in series to make 24v. The negative of this 24v is connected to the earth lead. The positive is connected to the terminal in the welder where the heavy welding current cable goes out and down to the torch.
The torch is thus premanent +24v.
turn the inverter and welder on, try the wire feed.
go weld!
go weld!
