MoreWellie
- Warwickshire, UK
Damn thing is so close to starting but I just can't get it to run and the grass is growing so I thought I would ask if anyone had useful suggestions for things I might have missed
Things I have tried, not necessarily in this order
1. clean air filter (tried starting without it)
2. replace fuel
3. strip and clean carb, including remove jet and poking all the holes
4. check valves are not gummed up and both move ok by finger pressure
5. check compression which is 130psi
6. checked and gapped plug (also made sure it is sparking)
7. replaced plug with new one
8. checked blade doesn't revolve when start cord pulled gently
9. removed exhaust and checked but there wasn't a spark arrestor fitted
it is so close to running. when using the pull start, if I pull a couple of times with choke on and then pull it back to full throttle, where the choke is just off, the engine will fire and keep firing for perhaps five seconds but peters out
in desperation I even tried easy start through air intake but that didn't make any difference
2. replace fuel
