quick question
i have a angle chassis section that is 3 mm thick and galvanized zinc plated
,,i think it is
and i need to welded to plane clean steel 4mm box section
can i weld on top of the galvanized or will it have to be cleaned off with a angle grinder first
your soposed to wear an air fed mask.
if you can get al the galv off it's ok but if you cant physicaly get at the back side of what your welding you can weld it fine but it'll still fume like hell
is it just a myth that your supposed to drink milk before welding galv?
I was always told a glass of milk and a piece of bread if you're unlucky enough to breathe it in. Supposed to take away the dizziness and churning stomach.
Dunno if it's still common practice, but they used to give milk to fellas who work in galvanizing plants, to stop their throats from falling off - or something.
