Hello Pavetim,
yes you can, given sufficient wall thickness. The success of what you need to do is another matter, if it is non critical in terms of strength then it will likely be OK as the thread depth, generally, is greater with a coarse thread. Obviously the thread will be less than perfect but if there is little load then you probably will get away with it.
Alec
Hello Andy,
you are quite right of course, brain must have been in neutral.
Alec
