as above or am i better getting them separate. would go air but have not got enough of it
anyone got a air mini da will this do instead with separate polisher
planning to paint whole car
let me know your thoughts cheers
A little more info would be good.......
As I am sure Steve (Langy) will tell you if you are polishing car paint unless you have some sort of experience BE WARNED....a polisher can rip your newly laid fresh paint to shreds, you can either polish right through it, or if c over b actually melt and burn it (especially on edges and sharp corners) a machine polisher needs to run at 800-2500 approx rpm preferably with a speed controller built in, and don't even think about using a 9" grinder with a buffing / polishing head on it, wayyyyyyyy to fast, you need to be looking at...if its a one off....THIS....or one of THESE if it is to be a longer term thing, now if you want a body prep tool prior to painting, then yes you want a DA.....two totally different animals, and seeing as you specced electric. then something along THESE lines is what you would be looking for, i hope any or all of the above is of some help to you.
It always ends in tears
Wish i had a pound for everytime i've seen a grinder used as a polisherIt always ends in tears
