Hi,
want to rig up a beam to run a beam roller and block and tackle on so i can load stuff onto the mill more easily.
The workshop has 6" RSJ's running front to back so the plan is to bolt in a cross beam that I can then run the roller on.
Ideally I only want to use a beam with a 100mm height as there is limited clearance with the timbers that support the mezzanine above.
Have seen universal columns that can be used as beams in 100mm x 100mm which would be ideal, but just want to check what load a 100mm x 100m UC would take with a 2m span.
Anyone handy with the calculator?
Cheers,
MM
Cheers,
MM
