QUESTION, Im more of a stick welder. but i bought a Hobart 187 wich can be used with or without gas. i don't want the extra expense of renting the bottle. so i would probably just use flux wire. instead of argon and co2 mixture. my book says you can use 100% co2 as well. thru my work i have access to plain co2 tanks at no cost. the kind that run soda machines, anyway wich is better flux wire or solid wire with the plain co2 for welding in your opinion. im sure the flux wire is more expensive than the plain but is it worth it. not sure if i would ever need to weld aluminum. but is nice to have that option. any help or advice thanks turk
