Hi everyone, I have been reading this site and forum for a while now and have found it very valuable so far. I am about to start welding for the first time, so wanted to get some final advice before finally deciding on a machine.
The Clarke range seem to get very good reviews for DIY work so I have looked at a few of them, but I'm open to recommendations for all brands.
My requirements are:
1) Budget of around £300.
2) Welding mild steel from 1mm right up to about 6mm (more on this later).
3) Very rarely I may need to do very minor welding outside - would it be worth going for a machine which can also work gasless?
On the subject of metal thickness, one of the projects I need to undertake is detailed here: http://www.diygokarts.com/kart-plans/steering-plan-spindles.html
The brackets in fig 2 and 3 are made of 6mm mild steel. Would a 150A MIG be able to tackle this with special preparation? I took a look at the thickness guidelines on this forum, and it looks like 6mm is pushing it for a 150A machine. Can you weld thicker material by using thicker wire?
Would I be better finding a more powerful used machine for that budget instead in order to properly weld 6mm steel.
I'm very keen to hear your thoughts and opinions. I am just starting out with it all, so looking to gain as much as information as possible to make an informed purchase, instead of ending up with an unsuitable machine.
