johnakay
I'm considering in buying small tig welder for light work such as tubings max 2mm wall/brackets 3mm.
I won't be welding continuously ,I still use my mig for most work.
also I can learn to tig and once I'm good enough then I can go and work for a company part time.
in the BOC catalogue there are 3 at the price more suitable for my wallet.
Victor 175 TE full kit,current range 5-175 duty cycle 20% @ 175. £504.37
these do not inc torch and can't find any info on the net
Ryval 130mma/lift tig machine current range 20-130,duty cycle tig 100%.mma 35% £195.95
same as above except goes to 175 amp £255.95
http://www.victortechnologies.eu/th...tID=2&SubCatID=2&ProdLineID=0&ProdID=3&brand=
identical looking to the Thermal Arc but appears to be a bit more spendy. I wouldn't pay much attention to things like duty cycle (less of a deal than it is with MIG) or to Rtechs bigging up the fact it runs off a 13A plug- it's only 160A, i'd be dissapointed if it didn't as my 200A Lincoln is happy enough running flat out from one. Above 160A it's pretty standard for machines to be specced for a 16A slow fuse though. Pulse can be a useful feature but IMO on thinner stuff than you're talking about. Personally i'd make the choice based on which retailer you can the best value from (service as well as price)
