Hello , my high frequency transformer burned out on this welding machine butters (NBC) Auto tig 160 ac/dc, can you help me with an electrical diagram, or with information where I could purchase another part of the same or equivalent? Thanks
That ferrite-cored transformer looks like a line-output transformer ( LOPT ) or flyback transformer from a television. They were used to provide the high voltage for the anode of the CRT tube. Description:
I have a Hobart Cybertig 300 S, square wave tig welder probably from the 80's. The high frequency quit working so I took the covers off the side to take a look at the spark gap. The gap was fine so I started taking a look at the rest of the circuit. What I found was that the primary side coil...
www.practicalmachinist.com
It also mentions using an ignition transformer from an oil boiler as a replacement part.
Here are some examples of these items for sale:
<ul style="margin-top:0; margin-bottom:0;"> <li dir="ltr">New/old stock line output transformer for colour television applications please refer to photos for additional info. Item will be well packaged and shipped second class via Royal Mail, thank you.</li> </ul>
Fans: Fan coils and motors failing due to boiler overheating will not be covered under warranty. How does this service works?. Failures or defects caused by misuse. IDEAL COMBI. Refurbished parts. Exclusions to warranty.
IDEAL BOILER HF IGNITION TRANSFORMER BERU 200230 A01, 0096100030100 174095. Condition is Used. Dispatched with Royal Mail Tracked 24.
www.ebay.co.uk
If no-one can supply a circuit diagram, you would need to investigate the layout and tracks of your HF board to reverse-engineer the circuit and select a suitable replacement part.
