I have managed to break the torch on my MIG at the weekend. I tapped the end to remove some dust and the brass tube inside the neck snapped. The previous owner of my house had left a knackered looking torch in the workshed and luckily that fitted and seemed to work rather better than the one I had just broken had ever done - wire feed was smoother, weld was smoother!
So.... if you were to buy a really nice eurotorch that would suit the welder above, what would you recommend. I usually use 0.8mm (often flux cored wire). I will need to do some body work with this machine at some point so may use 0.6mm wire then.
What recommendations would you have?
