I notice quite a few people doing butt welds and the panel fit is not "daylight proof". The problem is compounded by the cutout 'ole usually being somewhat imperfect.
Those wonderful zirconium flap discs?
Buy a drill mandrel to suit the flap disc hole - 14-16-22mm etc.
Fit it into a 1000-1300rpm cordless drill - not a mains drill or angle grinder.
Lay it on your leg and with the lower RPM you can shape that patch with incredible precision to get a ridiculously perfect fit in the most bizarre hole.
Do not try it with an angle grinder, edge on it will throw 0.8-0.9-1.0mm auto body steel around the room, too fast, too aggressive. You want a slow cordless drill, the zirconium flaps are quite superb compared to hit-n-miss knibblers & snips in rounding, dipping, shaping. Very quick n easy, just watch the heat on your fingers (& panel).
Found out the car uses 0.8mm skin, but 0.7mm wheel arch liner - now that is annoying because it is the one area where you get pin-worms which means it is very easy to literally "bang" a 1/4" hole before you blink. If the welder will not weld, it may not be the tool, it may not be the user, you just need to cut a bit further :-) How true it is "if you can see an inch you have six to weld".
