stee1e Member Messages 73 Location Aylesbury Jan 6, 2015 #1 Would something like this be suitable to heat up 10mm round bar to be able to bend it in a vice?
Spark plug Member Messages 4,036 Location Durham, England Jan 6, 2015 #2 It wouldn't be ideal, mapp gas would be better.
Parm Respect The Sound System Messages 17,901 Location Towcester Jan 6, 2015 #4 Mapp gas is better but if its just a one off job butane torch is by far the cheaper option
P piman Member Messages 1,901 Location Oswestry Shropshire Jan 6, 2015 #5 Hello Steele, depending on how you want to bend it, but normally I would bend 10mm cold, even though I have an oxy/acetylene set. Alec
BrokenBiker Member Messages 13,135 Location Newport, South Wales Jan 6, 2015 #7 I bend it cold up to 90 degree bends, if I need anymore than that I heat it up with a mapp plumbers torch, or propane
O optima21 Member Messages 4,510 Location halifax, England Jan 6, 2015 #8 yeah its too cold in this weather for butane, thats why I have a propane cylinder for when I go camping because it too forever to make a decent cuppa at 5am when it was a bit nippy when using butane.
chunkolini celebrity artiste Messages 9,718 Location Swansea Jan 6, 2015 #9 To get simple angled bends just slip piece of box section over each end of the bar to lengthen it and do it manually.
P Powermyster Member Messages 282 Jan 6, 2015 #10 I regularly bend 12mm and 16mm round bar cold. I never put the oxy-acetylene on it Deoemding on what your doing you shouldn't really need heat
