Spark plug
- Durham, England
Right at work I've been asked to fix the main warehouse lighting system as it never worked correctly since the building was new. the building is about 5 years old and the. Buyer fell through before it was fully finished as it sat that way until the company I work for bought it, this was all before I worked there so I don't know exactly what has happened.
Anyway I have identified the probloems and just need to find a solution. First about 40 of the lights where connected to the peremenent live so where Un-switchable and the other was a large number of the emergencys where never wired so never worked.
The lights are high bay Sodium luminaries and about 50% combine a compact fluorescent emergency.
They are fed from 3p+n+e busbars with 2 switched lives and 1 peremenent live. The busbars are fed from 3 single pole MCB's.
So Bering fed from single pole MCB's if you lost the two lighting phases you could end up with a dark area and no emergency lighting is this acceptable, should the emergency lighting only operate under a total power loss situation or should they be fed from triple pole MCB's.
