Brainsparks30
New Member
- Third rock from the sun
I am still looking for a competent engineer/welder to make my minibus door and frame.
Pretty straightforward for a pro.
I would like to replace the double non working electric power doors with manual for simplicity.
I know it's probably easy for you, but whilst it might be simple, health prohibits my physically doing this even though I find it interesting.
I put a lot of money and effort into tools and gas cylinders before I discovered I could not do it.
I would like this as my 'car' soon to keep mobility scooter in.
VW T5 Tucana.
Measure/design door and frame.
Fabricate.
Install and finish.
Use something along the lines of an American RV door lock which could be imported. It will need a latch building.
It is an easy standing up job working box steel, right now could run power outside to do it though it may be moving soon. That's part of the problem, as to MOT again it needs working doors!
Minibus is hot zinc dipped branded box steel, I presume similar section is enough. I thought maybe plexiglass to cover instead of glass for security.
It might be possible to bring to you as a place of repair if not to far. It is quite big though for the weight.
I would need to remove the solar to bring to you to be on the safe side, which would be an ****.
I made custom brackets bonded onto the roof. I would like that finishing too actually, but needs ladders.
Currently at South Norfolk.
I would need to do remove the old doors on the passenger side, covering with a tarp overnight ready for the new door. Don't want it like that for too long.
So I would like quotes please of what to expect for measuring, design, fabrication and installation.
There are some facebook builds that can give an idea, one option is to make frame and fit RV door.
I can post some pictures here soon.
VW T5 Tucana.
Fabricate.
Install and finish.
