Yeah every oil heating system should have a fire valve, there are two types, one COULD be outside, possibly on the outside wall, with a remote heat sensor to indoors, or the other type is an inline valve (looks a bit like a mini stopcock) which would be near the boiler. Normally these will never be activated unless there has been a fire or excess heat. I'm thinking you haven't got one, so that's obviously not causing a restriction.
the plastic tank height should be ok, I mean it obvious worked before. I assume the tank is now full is it?? If there's only a small amount in it, you won't get a good head of oil so it would appear there isn't a good flow, the oil pump on the burner (once no air is present) should have the draw to feed itself.
I also assume you're running the burner whilst bleeding the valve? It may take several resets to get it going.
This is a good article on how to, although it's for the US, the principle is the same. http://www.wikihow.com/Restart-a-Furnace-After-Running-out-of-Oil
If you've got oil UP TO the burner, but not bleeding through, then you're half way there, just do what it says in this article and after a few attempts you should be ok!!
It has one of these. A little brass thingymajig?
How could this affect flow, what does it look like whne closed/ open?
Dan, thanks for your help.
In the end it turned out it was just extremely airlocked. Bled it last night and it fired up.
There was a serious amount of air in it compared to sat when i first tried. I suppose all the attmepted starts eventually built up enough pressure to force the air out.
Lesson learnt.
Thanks again.
Dan , The boiler is about 10 years old and its been run dry quite a few times for the past six years ( probably around 8 times each winter ) , it cuts off very quickly when its out of oil but yes I am concerned that it may cause premature failure . We also have no filter so this is not going to help either , I keep looking on ebay for a spare burner but they are always too far away and postage to Donegal is extortionate from mainland UK.
