Usually in special at Aldi or Lidl for less than a tenner….unless it was a decent quality one throw it in the bin and get another one
digital verniers
corect vernier is a measurement. its a vernier caliperBin 'em.
Purely for the fact there's no such thing as 'digital verniers'... ;-)
It would take a bloody good knock to break the LCD on a Vernier caliper.. its a vernier caliper![]()
This ^^.Usually in special at Aldi or Lidl for less than a tenner….
So unless you need accuracy for building a nuclear power station, they ought to be good enough….tbh, I have a cheap digital one from Harbor Freight when I was in the States last, they serve me well enough, if I need better accuracy then it’s time for Mike to come out and play..
Takes me back to first year undergrad lab one of the set experiments was making anIts quite an art to change LCD's. I must go with the general consensus.
Bin em.
The LCD itself is a couple of thin glass plates with the liquid crystals held in between.
The connections are conductive traces etched and plated onto the glass.
The connections are conductive rubber strips that contain as many "wires " as needed by the LCD to operate.
The rubber strips are "very accurately " positioned on the circuit board, and the LCD is placed precisly on top of the rubber strips.
Then you screw it all back together, OR if its a cheap setup, clip the little keeper springs back onto the unit.
There is an auction site that sells excellent units WITH the calibration certificate for $30 Au, about 18 quid for you.
Specs:
Features:
Inch/Metric/Fractions conversion switch.
0 calibration switch.
Automatic On / Off.
Easy-to-read LCD display.
Durable stainless steel construction.
Specification:
Range: 0.01mm to 150mm / 0.001 Inch to 6 Inch
Resolution: 0.01mm/0.0004"
Accuracy: ±0.04mm/0.0016”
Battery: 1 x LR44 Button Battery (included)
Total Length: 236mm/7.7"
Material:Stainless Steel
Package Includes:
1 x Digital Caliper
1 x Box
Joe
