I cut two keyways in bores this week using the lathe. I ground up a simple tool the required width (3/16"), put it in a boring bar and pushed it in and out until i was at depth. Works well and not as time consuming as you would think. The length of the bar is the only thing limiting the depth you can reach.
Be the type of job I'd get my little hand shaper out for.Probably what I’ll end up doing. It doesn't need to be all the way through as the key only sits in 20mm.
