C
Chris Stevens
Guest
Did you use Tig brazing rods? They are not the same as those for gas brazing. Silver solder is probably better for joining a bush to steel sleeve anyway.
TIG brazing is relatively straightforward.
The TIG torch needs a thoriated tungsten
and dc current (torch +).
Brass/bronze bushes are usually described/sold as 'oil filled phosphor bronze' or 'sintered bronze'. AIUI they're usually neither and are commonly oil impregnated leaded bronzes or sintered manganese bronze which is actually a brass and has a fair bit of zinc in it. Oil, lead and/or zinc all ruin weldability and brazability, especially with TIG because TIG brazing filler wires all have a melting temp a fair bit higher than oxy fuel wires as they don't have any zinc in them i.e. with TIG brazing the melting point of the filler wires is usually higher than whatever flavour of brass or bronze that part is made fromI think I stumbled onto that last night? Got some silicon bronze rods and wanted to try and join a brass bushing to a piece of steel but the brass just kept developing loads and loads of black smoke and got all charred and nothing would stick to it. I ground it and the steel clean before starting of course. Laying beads with it on low amps wasn't terribly difficult, though it turned out matte looking.
Phosphor bronze is a copper alloy. It's mostly copper with ~ 6 or 7% tin in itNot sure I would have used copper bearing rod for that job? I find phosphor bronze is more suited to brazing dissimilar materials
DC+ is a typo or mistake. Not the only example in SIF-weldability guides. DCEP (DC+) is sometimes used for a few more specialist applications but it's not practical for most stuff as about 2/3 of the arcs heat occurs at the +ve electrode so you need a much larger tungsten than normal or it just melts
Lots of zinc results in whitish/light gray 'soot' over everything including the torch and often loads of the stuff floating about in the air as it's volatised and boils out of the material so i'm guessing you had a leaded bronze?
In theory should be possible to silver solder with TIG. There's too much zinc in most flavours of silver solder though so limited choices of wire, they're probably all the even more spendy flavours with higher Ag content(?) and i'd have guessed that it'd be difficult to avoid overheating the wire as the arc is much higher temp than an oxy fuel flame and the heat, as said, is far more focused. I've never tried because silver solder is expensive stuff and i can't believe TIG offers any advantages over oxyfuel
There's nothing inherently wrong about using a TIG to solder, at the end of the day soldering/brazing/welding just needs a heat source and something to protect and/or actively clean the metal. An open flame, an oven, induction heating or a leccy arc can all provide the former with either a flux or gas shielding for the later
SIF 968 available in small quantities on Ebay, wonder how that compares to No8?
