Ubique
- East Midlands
It may be a simple question - and I'm probably missing something....
I need to make an adjustable frame, the 'core' will be 25mm x 25mm x 3mm box, I need something to fit over it, as a close fit - the nearest I can see is 30mm x 30mm x 2.5mm, which would be an interference fit or 30mm x 30mm x 2mm which would be a bit sloppy. The larger section would be bearing the load, approx 400kg across three points, 100mm long. 2mm would fit, 2.5mm is acceptable but tight, there is no 3mm option that I can see. It needs to be a good fit to prevent any wobble which would cause alignment issues.
Thanks.
Thanks.
