Having a bit of trouble with this boiler, wife run the hot tap in the bath last week, complaining that the water was going from luke warm to cold, we heard the boiler making a noise and I noticed the needle on the gauge bouncing around, going into the red zone results in it shutting down/me doing a reset.
My first thought were that there could be trapped air in the system/pump, I haven't found any yet, next thought were that the mains water feed had dropped/been turned down, again not what I can see. Only other thing I can think of is the pump itself, can it not keep up with the flow required from the bath tap??.....but everything is fine when the kitchen or bathroom basins hot taps are turned.
Over the last couple of years I've fitted a new PCB and diverter valve assembly to this boiler, that did solve the problem of no hot water coming out of the taps,.....I've never had a combi boiler, would like to know even more/how they actually work. From what I gather, it's normal for the flame to extinguish once the 80 degree light has been on for a while even whilst you are calling for more hot water? Mine does this, it does fire back up, cycle on/off when the temp drops to the 70 light but by that time, the water that's in the section of pipe from the boiler to the tap isn't exactly hot. That section of pipe is longer than in most other bungalows I'd guess, our boiler is in the loft rather than kitchen.
The system is kinda currently working, wife run a bath today and said that it were OK, no boiler noise and the water were warm enough, not boiling though,.....it's always been very hot from the kitchen and basin taps though.
Any tips ideas chaps?
