I'm slowly building my welding tools up over time.
However, what make of tools does everyone rate as the best?
I bought a Sealey 100mm angle grindera few months ago, but found that everything is made for 115, so I just went out and bought a Bosch 115. Its much lighter than the Sealey!
Is Bosch good for trade / heavy work? Or is it upper end DIY stuff? It was cheaper than the Sealey which I wasn't expecting.
Seems to be so many out there, my carpenter mates say only use Hitachi and Makita, others say Powerbase xtreme stuff is ok as its so cheap and is re-badged black and decker.
What do you think or know is best for fabrication?
Thanks!
Thanks!
The locking nut jammed on so tight that I had to use a two foot extension pipe over the removal wrench (the one with the two pins) to get it off. This in turn distorted the holes for the removal wrench, plus broke a tooth off the main gear where it engages with the blade lock button (which also suffered damage).
Are the name brands better? In my opinion yes but you pay for that quality.
, but IMHO are the most comfortable to use for long periods of time, and I like the fact that the switch is on the back not the side.
