Depending on the arrangement of the kitchen appliances, it could be Fridge Under Troubled WaterCan you recognise the tune it is singing?
Yes if you do nothing about it but not dangerous.Hello, my oil fired boiler has started singing and then kettle-ing.
Should I worry?
i beg to disagreeYes if you do nothing about it but not dangerous.
Boiler kettling is almost always about overheating, Why?
I disagree, most European and UK boilers have several fail systems to prevent such things going that far.i beg to disagree
it is one of the dangerous things as its a sign that your water is turning to steam and that part is dangerous
once that happens it will find a weakest point and blow through that point boiling steam has killed many a person never mind burnt them badly
steam trains are known for for boiling steam and exploding with many an engine crew killed if they survived the steam explosion that certainly didnt last long
Twice for me, it's a rare occurrence.ive only once come across a boiler that has overheated and blasted boiling water and steam up the 22mm vent pipe and in to the cold water header tank .it cant run dry as it just refills the system if theres any loss of water
The kettling sound is the water boiling in the boiler, normally caused by the heat exchanger scaling up or filling with rust, if its a cast iron heat exchanger they can rumble on for years, the problem is that you're wasting a lot of energy just heating up the scale, as far as safety concerns, depending on the sytem its either open vented with a feed and expansion tank in the loft and it'll vent into that or its a sealed system with a 3 bar safety valve fitted but either way its safe.
A faulty boiler can cause steam but not to a point it is dangerous for the consumer.
That blow through you mention is prevented by a PRV and is one such feature to prevent steam build up.
Many a home owner has found no boiler pressure or the PRV dripping on an outside wall.
This will be due to a faulty PRV or the PRV is doing it's job and preventing serious kettling.
I can find no reference to a UK domestic/commercial boiler in the last 45 years, creating steam to the point it has caused injury to a user.
There are a few examples of cowboy installations where a UK boiler is/has become dangerous resulting in a devastating explosion, that is mainly down to gas, not steam.
Your steam train analogy, while not inaccurate, is a different beast to a CH gas or oil boiler of the last number of years.
Topical; it's the 200th anniversary of the Stockton-Darlington railway this weekend. The replica Locomotion No. 1 puffed backwards and forwards (delayed, there's a surprise) while people cheered.steam trains are known for for boiling steam and exploding with many an engine crew killed if they survived the steam explosion that certainly didnt last long
