Done that three times. Continues throwing the errorPress reset
You not gonna have a go yourself?Anyone know any good boiler engineers in east London. Vaillant EcoTec Plus 831 has thrown a wobbly. Error code F28.
Ignition failure.
i would be well I did it was the PCB in my case!You not gonna have a go yourself?
Properly muller it then create a thread on here saying the company is ****e ?
Vaillant F.28 Boiler Fault Code
Error Description
Failure during start-up: ignition unsuccessful.
Error Cause
• Gas meter defective or gas pressure regulator has triggered,
• Air in gas
• Gas flow pressure too low
• Thermal isolator device (TAE) has triggered
• Condensate duct blocked
• Incorrect gas restrictor
• Incorrect ET gas valve
• Fault on the gas valve
• Multiple plug on PCB incorrectly plugged in
• Break in cable harness
• Ignition system (ignition transformer, ignition cable, ignition plug, ignition electrode) defective
Fix Vaillant F.28 Error Code
There are a range of issues that can cause an F.28 error code to occur, if you encounter this issue - first check to ensure gas is coming into your property. If it is then call a Gas Safe engineer to test your system and isolate the fault.
I'd have a go, it's only a bit of natural gas.You not gonna have a go yourself?
Right switching the boiler off completely and then back on has cured the issue.
So it's either electrodes or gas valve.
A PCB would either work or it wouldn't in my experience.
If I had been a gas engineer I wouldn't be posting asking for help would I.Then you have never been a gas engineer, PCBs cause more random problems than just fail
In most other electronics, a pcb fault causes an error that isn't rectified by a power cycle.
You obviously haven't had much experience of other electronics thenIn most other electronics, a pcb fault causes an error that isn't rectified by a power cycle.
You obviously haven't had much experience of other electronics then![]()
And make people irritableIt's wild how even modest swings in things like temperature and humidity can cause failing electronics to go loopy.
