Kawasaki James
New Member
- Wakefield
Hi. I've blown a small selenium rectifier on my TIG. I don't know what else (if anything) it's taken out but it would be dead handy if anyone's had any experience of this, or even better a wiring schematic. I'm guessing it feeds a DC coil on one of the relays but the wiring is faded, filthy and a pain to trace.
. I found everything but one spring. Also noted that one of the 430V terminal screws was stripped and there was some burning at the loose connection. Anyway, as the argon spot weld setting never gets used (it requires a few terminal changes inside the set) I pinched some of the good components from that terminal to renovate the rest of the switch. Fortunately the terminal that was permanently closed was a redundant one. I note that these cam switches are not necessarily 'fail-safe'. What had happened is that the plastic cam follower had disintegrated so the cam was unable to open the contacts and the spring held them closed.
