i use one of these
If you do and they are an excellent torch do not leave the cannister on for long periods unused as it can block the reg and then you have to buy a new one as they are not repairable
Also make sure you burn of the gas that is left in the torch after you have removed the canister
ok, thanks for the tips.![]()
Its Benzomatic. I got it from my local plumbers merchant, but you can get them from usual places online
For a big bad un you will need oxy/ accet or oxy/prop. Albee cylinders? Ok that's a bigger cost but make sure the MAPP gas is up to the sort of things you work on before buying
My day acquired one from work because the spark had gone. I had a look and the wire was sparking to the body near the lock button, a little bit of insulating tape and it was working againIncidentally, the ignition unit failed on mine. I called up rothenberger and they sent me a service kit out, FOC.
. I unscrewed the cylinder a couple of weeks ago and it leaked so now I keep it with the cylinder on.
