Jelly_Sheffield
Time is an illusion. Lunchtime doubly so.
- Sheffield, UK
So I want to finish the rust repairs I started on the Hilux last summer.
I have OEM colour matched metallic base coat and clear coat in 1k, a pressure pot sprayer, and more air than I could possibly want.
This allowed me to respray the bed-topper very successfully two years ago and that's holding up great with an ok colour match.
The repairs were all sprayed with cold galv and stone chip at the time, and it's held up variably well.
My plan is to sand back, treat any rust spots that developed, spray with cold galv again, add some filler to address my less than stellar sheet metal forming skills, sand a bit more and then prime with high build primer.
At that point I have two options:
- respray the entire quarter panel.
- blend the repaired areas into the undamaged paint.
I am trying to understand the blending process, from what my online research tells me I need to:
• key the area to be resprayed,
• then spray that area as normal,
• deliberately overspray around the repair area whilst "degrading" the paint spray on those areas.
In my mind that will end up looking weird because there's base coat going over clear coat on the non-repair area, and the "degraded" clear coat spray over it won't form a film and will just look cloudy and ****.
My thought process is that I need to:
→Key the whole area being sprayed to at least remove the clear coat everywhere,
→spray the base coat as normal onto the repair and feather that paint into the keyed area which has base coat but no clear coat,
→clear coat over the entire of the base coat and feather that into the unkeyed clear coat.
→use a buffer and cutting compound to blend the clear coat visually to remove any cloudy appearance.
Am I on roughly the right track?
Edit: It's ultimately an 18 year old pickup which gets the hell beaten out of it... Not aiming for perfection just for the end result not to look horribly incompetent.
Also a good place to get some practice in for a job that actually matters.
