Morning all.
This is just a quick heads up really regarding the above product. It’s a water soluble corrosion inhibitor that I’ve recently started using on my cars to prevent the brake discs rusting over when they’re parked up for any length of time. It’s totally safe to spray it directly onto the friction surface. As is often the case however, it has other uses. It’s great for protecting bare steel once cleaned up after cutting, welding etc. and unlike oils doesn’t need cleaning off. I’ve had a pair of unpainted gate frames stored for the last month or so that I sprayed and there’s not a spot of rust on them. I’ve no affiliation with Bilt Hamber, I just thought this product may be of interest as I’m not aware of anything similar on the market(?). At the recommended dilution ratio it works out cheap too!
