as part of a project I have some 12mm square solid stainless. I have drilled a through hole but it is on the wrong axis (90 degrees out) compared to other parts on the square bar.
What is the best way to fill this 5mm hole, so that when I drill the hole in the correct place on the other axis and can still be tapped m6 and maintain strength in the bar?
I was thinking make a pin to fit the hole, counter sink each side of the hole and weld the pin in then machine the surface???
Thanks
Thanks
