I don't have a vice yet would some pegs welded to my bench doJust a straight 90??
Soft jaws, vice, lump of tube to sleeve it and pull.
I didn't think of thatYeah. Anything that will firmly hold one end while you pull on the other
Drill a 10mm hole in the bench corner if you like and bend it in that.
Don't suppose you could put a diagram of It upIf you just pull it/hammer it, it will bend the piece you are pulling, you will not end up with a straight bar each side of the bend. You need to pull/push it as close to the bend as possible. A couple of bits of tube slipped over or a simple jig made from wood or bits of metal is best.
Thanks for that I will try that way because the pegs welded to my bench didn't work I just tipped it over
