Which is the better shielding gas for MIG welding? We are currently using CO2 gas as the shielding gas. The welding parameters are Voltage: 18-22V and Current is 120-160Amps. We are welding various sheet thickness ranging from 1.6mm to 4.8mm. Which is the suitable welding parameter? The welding machine used is CHOWEL 400.
) A Argon Co2 mix of any description would give you instant improvements, but uts quite expensive in comparison......if you have a large welding operation, you could speak to Praxair, Ellenbarrie gases etc about bulk supply storage tanks at your facility and mix your own.
