surfer4life
New Member
Hi all, ive been searching threads on here but can't find a definitive answer.
I have bought a brand new door for my mercedes vario truck, but i need to extend the bottom of the door as it has had a step fitted when new. I have bought some galvanised steel sheet and will weld that onto the bottom of the mild steel ungalvanised door. What primer do i use to prime the welds and where the galvanised coating has melted away, and also the bare steel of the new door where the weld occured?
I actually bought some zinsser 123 plus as i thought that was what you used to prime galvanised steel before top coating, but now i had read the instructions it says not to use on bare mild steel as flash rusting may occur!!!!! £15 down the drain
I have read varying responses in different threads but none specifically relate to welding galvanised steel.
I also have some rust patches to sort on the body, so would prefer the primer to also be used on the bare metal before priming, or is that asking too much ;-)
