ronan
I went out to the shed earlier to mooch about for an hour and was amazed to see the amount of condensation on the lathe and mill, the water was literally dripping off both machines.
Aerosol 3 in 1 oil is normally what i use on any bare metal surfaces to stop rust but it appeared to emulsify with the water and was white on the metal. I wiped off the lot with rag and coated the machines with wd40 instead.
Whats the best thing to use in this situation to protect from rust ?
i have a a large building drier but its no use without heat in building concrete floor and tin sheeting are a nightmare i just spray machinery with wd 40 and cover them up and then wipe down before use
