BrokenBiker
- Newport, South Wales
I have a need to make a small curved heat shield so I can get a torch on a bleed nipple without melting pipes, slide pin covers and abs wiring that is fairly close to the nipple...
I have 3mm stainless, 3mm ally, an assortment of mild steel and some 15mm copper pipe I can slit open and flatten, but it's very thin.
I have enough of all materials to make something as big as possible and curved to reflect heat away from anything that needs to stay cool.
Which is best option? The bleed nipple is about half inch from the feed hose and maybe inch from abs wires, 2 inches from the slide pin area that has white grease in the rubber end cap and caliper will be in situ at the time, although with wheel removed there's a fair bit of torch swinging space.
I feel ally will be the best? But I am wary of whatever I use radiating heat behind so I was thinking maybe 2 bits tacked back to back with a bit of an air gap to try and prevent this?
