here is your volunteerI've got an antirollbar that's a thick as a broom handle and need it bending so it misses my engine, how do I do it, or can we have a willing volunteer??
you'll have to anneal it first,then after bending re -temper it not sure what temp'[maybe approx 280degrees], you'll need to clean the surface back to bright then as you heat it watch for the colours to appear on the surface telling you your at the correct temp' then you can quench in tepid water
its not that simple it must be heated up to the correct temperature or it will either snap or be a soft as sh . t and have no spring and may bendI'd heat it up, bend it, then clean it up, heat it a bit then quench it in oil. Less technical![]()
