I apologies in advance if this sonuds daft but im making a spare wheel carrier to fit on to a tow hitch on my mga, the problem is that it is 10 mm x 100mm flat bar that im using and i have no way to bend it, my plan is to cut just over half way through leaving about 4mm and bend it in the vice and then weld up the gap witch will be on the out side of the 90 degree angle, my question is will this be as strong as it would be if the bar had been bent by a press and if not is it still accepable, thanks for any advice
