I tried a lap/t joint at the weekend, with no success.
Tried to get the rod in tight into the corner, but kept sticking. If the rod didn't stick, a bead formed on either side of the corner, but didn't build up in between. I was using 2.5mm rods on 3mm steel.
I'm wondering if I should have tried running a bead along one piece, cleaned the slag off and added a bead joining the other piece.
When prepping the steel, I bevelled one piece of steel, only later reading that's not the way for lap or t joints. Could my problem have been a 'hollow' in the steel in the joint?
