Very good Chris, see the dros been put to good use.
.Wait until you start with the milling. That will get your head in knots, in a good way.
, now i know why i need a rotary tableNice work. Is that before or after the rad?
Its after the rad , i was having overheating issues when the going gets tough , im hoping this helps out , you can buy them at £30 a pop but i thought it would be good practice to make one
Chris could try a separate earth to see if that cures. Theres usually an earth terminal on back of readout.
Saying that i do have same problems on the lathe tailstock magnetic until i move it once any direction. 2 axis on mill do the same now and again notably the downfeed and X axis. a strip down and clean of glass sorts but yours is the magnetic.
Have a word with Machine DRO and tell them you are not the only one.
, without inserts and they are a bit scarce on the bay .
by the look of the rad the fins dont look very good for airflow at the bottom end looks like it's been jet washed too many times
jet washing rads/inter coolers is not a good idea flattens the fins so no airflow then gets too hot seen it done loads of times at off road play days
