At the end of silage cutting this year there was a noise from the harvester
so before putting it away for the winter I decided to strip it down and see what the problem was.As it turned out a bearing on the knife cylinder had collapsed.
I have all the parts removed around it but the inner race is still stuck on the shaft, i cant get a grinder in to cut it and there is nowhere to hook the legs of the puller.i was thinking of welding something onto the bearing to hook the
puller to, is there any special rod or prep i should do to welld to bearing?
anytnings worth a try mind
