Battery adapters are mentioned fairly often on here, I've used a cheap generic unit to run new Dewalt batteries on one old Dewalt unit that wasn't worth replacing and it works fine.
I suspect it all depends on which brands your are converting too/from.
So to the story,
Youngest bought all eldest's old Ryobi kit and he only a couple of decent size batteries and they just don't last like my Dewalt ones do. We bought a Dewalt to Ryobi adapter and it works fine and the grinder runs much better with the Dewalt battery. I had always stressed that he shouldn't run them till they are absolutely dead because the way the protection is done in Dewalt and Ryobi is different. This week he was grinding some bits for his tractor and borrowed a couple of my batteries. Flattened the first so put it on charge. He must have forgot what I said about not nrunning them completely dead because the seocnd battery does not charge now. I'd tried all the usual, brief spike to get enough power to make it charge. I opened it up to have a look and found that 3 out of the 5 banks of cells are down as low as 0.5V. I'll try and get some charge into those banks with a bench PSU
There is no doubt that it was running the Dewalt battery on the Ryobi grinder and running totally dead that's killed it so it's something to be aware of if using an adapter.
Since this happened we've order a non genuine Ryobi battery and I have to say for the £22 it cost it's very nice, not sure if it really is 6ah but the reality is I'm looking at a £50 doorstop Dewalt battery at the moment.
I am fully aware I can fix my Dewalt with some new cells but I'm going to try and charge the individual banks in situ with a current/voltage controlled supply first
If you are using battery adapters, remember why you are using them and use them with caution. I had always been someone who did not want multiple battery platforms but sadly sometimes it's the only way. I am sure many of you use them all the time and have no issues but it's not a coincidence that a battery I've run with no issues for 4 years suddenly dies after running on a battery adapter.
So to the story,
