Two questions please, I read that some advocate adding a little hardener to the base coat (the same as in the clear coat) which helps both scratch resistance and clear coat adhesion. So is it necessary or advised - to remind you I`m a newbie but with all the safety gear. PLUS how long can I leave the last base coat before I must put on the 2K clear coat? If left do I sand it down.
