Plenty of forums elsewhere that this question could have been posted in but the floor needs to bear the load of machinery and not vibrate unduly so this is the first place to ask.
I have a barn that needs a floor. It is 12Mx5M rectangle. Currently it is 200 year old dirt floor. Heaviest machine is shy of 1,800Kg. No long bed lathes involved, the four soon to be five machines are compact and most sources say no special requirements on depth of base.
Kearns S type manual suggests 12" concrete but reliable sources say that machine is happy on a lot less.
For anyone who has had to lay a floor or called in contractors to lay a 60M2 or larger floor I am eager to know what you specified and even what you spent.
My current notion is to dig out to +30cm, lay mixed ballast to 15cm, sand then Kingspan or other batts to 3.5cm on top of membrane and pumped concrete on rebar to 12cm.
Power float finish and epoxy surface coat.
It has to be pumped concrete as the site is on a tight bend on a narrow road with no turn in for a mixer and the time on site needs to be minimal.
It is over 7m3 at 12cm depth and as yet I have not a clue what mixer capacity is in France. Work I have done in the UK it is usually 6M3.
