bar coat is spirit based so yes charcoal filter will be fineCan I use a standard charcoal mask with this as I've got a golf which had been painted before and keeps reacting so was going to bar coat it but msds says airfed can't see why cheers or I was going to just prime it in 1k water base
I don't understand how it doesn't work for people never had an issue when ive needed to use itJust a normal dust mask will be ok when you have to sand it all off again because it hasn't worked properly.This is based on my experiences of barcoat.
don't thin it down give a good coat so its 100% covered leave 1 hour prime straight on top do not flat itWell I will give it a go how long did you leave it before priming as it says 1 hr and then overcoatable
ive never had a problem, I found it goes on very well, maybe you had a duff tinI found it sprayed out really dry, then when I sorted that out and had the top coats on it all crazed after about 2 months.Tried it a few times and this happened.
As would I.I would seal it with epoxy primer
