Beanmetalworks
hi just wanted to quickly ask what sort of tension should you have on a metal cuttting bandsaw mines giving me bit of gip!! if you need more infomation let me know as dont know what info you may need??
what type of blades do you use??On my Clarke I nip it up fairly tight, start the saw cutting then back it off half a turn at a time until it starts to slip, then tighten it one turn
Because there can be long periods of no use I always back it off 2 full turns when finished, just my personal idea of removing pressure on things sitting...may not actually make any difference at all in reality.
It must be a decent way of doing it because my blades last for ages.
Oh no that was not what I wanted to hear......I used Machine Marts blades with a drop of cutting oil on the steel, I once bought a 'good' bi metal blade for 3x the price and it lasted no longer, in fact I was fairly sure it only lasted half the cuts.
