Hi,
Just got myself a COSMO D/P 130Amp MIG welder. I aim to do some aluminium welding but started on a 1mm steel plate to practice using CO2/Argon mix and 0.8mm wire. Try as I might at all settings High -> Low and various speeds all I get is balls of weld wire on the surface and no penetration. I did notice that it is actually flux cored wire they supplied in the kit.
I thought I may as well have a stab at the alu for the hell of it and started at low settings and various speeds.....balls again on the surface. Here I used pure argon and non-fluxed alu wire. I thought sod it and whacked it upto the high setting and thought I'd blow some holes in the material (1.5mm alu sheet) and work back. Even on high I cannot get any penetration and end up with balls of alu on the surface.
I rubbed the steel/alu back to shiny metal and varied the gas amount with both.
I got quite a lot of burning back to the tip whilst trying the alu...and now have 3 tips to drill back out
If anyone has any idea what is going on that would be great as I'm contemplating black magic spells to help
Cheers
John
Cheers
John
