If it is, it ain't mine! I don't have one.Hold down clamp for a mitre saw? And a bit that stops it tipping too far when cutting off 90 vertical?
Aaaaah! Hang on, is a mitre saw the same as a chop saw?Pretty sure you are right, I was after another hold down clamp for my lumberjack as they only supply one.
@RWD3M if you don't want it I'll have it![]()
Does your chop saw tilt from side to side??Well I'll be! It looks like they are for my little chop saw! What I don't get though is what that bit at the top of the picture does. It loos like it screws into the back of the base but no idea why![]()
No idea, I'll have a look.Does your chop saw tilt from side to side??
Do I win a prize?Hold down clamp for a mitre saw? And a bit that stops it tipping too far when cutting off 90 vertical?
No it doesn't but it did successfully put square cuts on all the 4 x 2 I used in my new shedDoes it slide on rails?
Thats a good and better than an evolution then, can't seem to get the fence square to the blade somehowNo it doesn't but it did successfully put square cuts on all the 4 x 2 I used in my new shed![]()
Ooh, mine is an Evolution! Just a small one, green if it makes any difference.Thats a good and better than an evolution then, can't seem to get the fence square to the blade somehow![]()
I have the orange sliding mitre saw. The fence should be one piece with a low loop in the middle to give the blade room. Seems to be off straight each side of the middle.Ooh, mine is an Evolution! Just a small one, green if it makes any difference.
