Hi all,
I'm welding some 20mm box to 22mm tube, tube horizonal top & bottom and box verical sort of like:
. I I
The problem is the horizontal tubes need to be as close to perfectly straight as possible. I've tried clamping some angle onto the tube with G clamps but I'm not convinced they're getting enough purchase as they are slipping on the tube. When it's cooled down & I take the clamps off it's pulled down (into the middle) at each end, although inbetween the uprights still seems perfectly flat
Thoughts so far if anyone can confirm or deny?
1 - vice grips may be batter than G clamps?
2 - move the uprights to the far edge and add a 3rd in the middle?
3 - tack a piece of box perpendicular to the 2 uprights as a brace to reduce movement?
4 - try and straighten them with the blowtorch on the back of them
Or if anyone has any other ideas I'd be grateful
Cheers
jim
. I I
Cheers
jim
