Afternoon all.
I need to remove a large number of Avdelok fasteners and only have limited access to the stem side. So far I’ve been grinding the heads off which is tedious, dirty, and inevitably results in the occasional gouge in the outer panels which I plan to reuse…. Avdel and Huck both make a splitter which removes the collars but they’re expensive (very!). It did get me thinking though about other ways to remove them. I’m leaning towards trying a heavy duty metal cutting blade in my Fein multi tool and cutting through the collars, I need to check it will reach through the access holes though. The other option is grind a slot in an SDS+ chisel bit deep enough to clear the stem and try chiselling through them using my Hitachi drill. I’m not sure if the collars are as hard as the rivets themselves (which are hard!)?
Any thoughts or ideas would be welcome!
